Ncosper's avatar
Ncosper
Follower
Oct 19, 2023
Rbr850 mesh systems makes iPhone ask for password every connection
Within the last week my Orbi system that I’ve only had for a couple of months has started making my iPhone require a password every single time it connects. This is probably 20-30 times per day and extremely annoying. I’ve tried every troubleshooting method I can find, including reset iPhone network settings, disabling private ip, resetting the router. This doesn’t happen on my other router in the house that I have for a dedicated 2.4 network. It doesn’t happen on any other device except occasionally on one Apple TV.
I even tried rolling back the Orbi to older firmware. Nothing has helped at all.
Really need some guidance
1 Reply
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    How many RBS are deployed?
    What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
    Be sure to disable any MAC Address randomizers on phones and pads while at home:
    https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
