Loek
Feb 06, 2024Aspirant
RBR850 Multicast Stutter
Hi, While trying to play any multicast content, it stutters and lags. I think it might be due to a missing IGMP Snooping protocol. Orbi is in Router mode and connected via ether to the satelli...
CrimpOn
Feb 06, 2024Guru - Experienced User
IGMP appears in the user manual only in the context of IGMP Proxy, to allow devices on the LAN to receive multicast from the internet.
- CrimpOnFeb 06, 2024Guru - Experienced User
Are there any Ethernet switches in the network?
Some switches are known to have defective IGMP Snooping (cannot remember which, sorry)
- LoekFeb 09, 2024Aspirant
Hi,
Yeah one Netgear nighthawk, however it shouldn't be the issue because if I plug it directly in the satellites, the issue remains. Do you know what snooping is supposed to do and if it could help?
- FURRYe38Feb 09, 2024Guru - Experienced User
What is the brand and model# of the switch your using? Managed or non managed. If managed, then any IGMP protocols should be disabled if any RBS are ethernet connected to this switch.
