Leon61's avatar
Leon61
Follower
Jan 15, 2024
RBR850 multiroom issue with wired B&O resources
Hi,
I experience now for a long time multiroom issues (JOIN function) with my NetGear ORBI RBR850 and LAN wired connected with B&O resources. After investigation by B&O Denmark and a fully reset to factory settings the problem still exist. Only a plug out of the power supply for 1 minute helps as long as the B&O resources are on. After switching of; the multiroom functionality doesn't work anymore. It doesn''t take over the sound. It works just ones.
Kindly regards,
Leon G. (NL)
No RepliesBe the first to reply
