donawalt
Mar 15, 2021Hero - Experienced User
RBR850 needs a reboot every 2-4 days - how to stop?
I wanted to share with you a problem I have been seeing with my RBR850 installation plus 4 satellites. Periodically, maybe every 2-4 days, the performance in streaming from multiple Apple TV apps (li...
- Mar 20, 2021
Possible or your wifi environment is getting too saturated with wifi signals having that many RBS online. Remember, these things cover up to a good decent range so the wifi over lap will be out there a ways. So this should allow for more coverage and range using less RBS units. I get great coverage with just two or some times even 1 RBS in a 5000 sq ft home including basement.
Keep the 4th RBS as a backup in case something happens.
Enjoy.:smileywink:
donawalt
Some other config settings I forgot to add in the OP:
20/40 Coexistance is checked ON (mess up above);
WMM is on for 2.4 and 5.0;
CTS/RTS is 2347 for both 2.4 and 5.0;
Preambe mode Auto;
Power transmit is 100%.
Mar 15, 2021Guru - Experienced User
So the Apple TV is the only device to exhibit this problem? If so, you might check with the Mfr as well on this.
When this happens, which orbi unit is the ATV connected too?
What happens if you set 40Mhz only on the RBR.
LAG is enabled on the RBR and CM1200?
- donawaltMar 15, 2021Hero - Experienced User
No, it happens on all devices as far as I know. It just happened again this morning, and I checked my iPhone it was getting download speeds of 5 Mb per second. I rebooted the router, and the iPhone was getting 200 Mb per second.
Should I consider downgrading my firmware to Version 3.2.16.22? This has happened since I moved into this house, and I actually upgraded to Version 3.2.17.12 when I moved into the house. So I can say it's always happened on this firmware, and it did not happen on the prior version. But that could be circumstantial.
Do you mean I should uncheck "Enable 20/40 MHz Coexistence"? That just affects 2.4GHz, and these devices are all on 5 GHz right? If that's what you want me to try, I'll try that.
- FURRYe38Mar 15, 2021Guru - Experienced User
Ok thats good to know.
I would disable LAG on the CM and RBR. Apple and power cycle everything OFF for 1 minute then back ON.
Was either a power off of the Orbi system performed after update to v12 or a factory reset and setup from scratch done?
Yes only effects 2.4, something to try however in this case may not do anything.
I'm on v12 have have been for: LAG disable on my CM1200
Basic Information CPU Load 16.9118% Memory Usage(Used/Total) 208MB/496MB Flash Usage(Used/Total) 2955MB/4096MB Network Session(Active/Total) 488/65536 System Uptime 29:20:48:58 - donawaltMar 15, 2021Hero - Experienced User
Power off of the Orbi was done after the update, which was done in early February.
Are you saying:
I would disable LAG on the CM and RBR. Apple and power cycle everything OFF for 1 minute then back ON. AND reactivate LAG
Sorry, what does this mean:
Should I be comparing your stats to mine? Is that on the CM1200 modem? I can't remember seeing anything like that.
Thanks for your help!
