donawalt's avatar
donawalt
Hero - Experienced User
Mar 15, 2021
RBR850 needs a reboot every 2-4 days - how to stop?
I wanted to share with you a problem I have been seeing with my RBR850 installation plus 4 satellites. Periodically, maybe every 2-4 days, the performance in streaming from multiple Apple TV apps (li...
  • FURRYe38's avatar
    Possible or your wifi environment is getting too saturated with wifi signals having that many RBS online. Remember, these things cover up to a good decent range so the wifi over lap will be out there a ways. So this should allow for more coverage and range using less RBS units. I get great coverage with just two or some times even 1 RBS in a 5000 sq ft home including basement.
    Keep the 4th RBS as a backup in case something happens.
    Enjoy.:smileywink:
