donawalt
Mar 15, 2021Hero - Experienced User
RBR850 needs a reboot every 2-4 days - how to stop?
I wanted to share with you a problem I have been seeing with my RBR850 installation plus 4 satellites. Periodically, maybe every 2-4 days, the performance in streaming from multiple Apple TV apps (li...
- Mar 20, 2021
Possible or your wifi environment is getting too saturated with wifi signals having that many RBS online. Remember, these things cover up to a good decent range so the wifi over lap will be out there a ways. So this should allow for more coverage and range using less RBS units. I get great coverage with just two or some times even 1 RBS in a 5000 sq ft home including basement.
Keep the 4th RBS as a backup in case something happens.
Enjoy.:smileywink:
Mar 16, 2021Guru - Experienced User
Have you contacted NG support about your problem? Hoping NG will fix your problem with a FW upate maybe fruitless if you don't let them know about it.
Mikey94025 wrote:Your problem may be different from my RBR850 system issue, but I suggest try running without your satellites to eliminate any satellite-specific cause. I have an RBR850 and 3 satellites, but only run 1 satellite. After running for a day or two with more than 1 satellite, then any device connected to the extra satellite will not have internet connectivity. I don't recall what that satellite status said when this internet connectivity disruption occurs. Devices connected to the RBR850 continue to run just fine.
This was my original post: https://community.netgear.com/t5/Orbi-AX/RBS850-satellites-lose-internet-and-gateway-connectivity-several/td-p/1952486 . This afflicts 2 of my 3 satellites, so I have run with only 1 satellite for a long time. I need the 1 satellite running as an access point. The issue may be caused by too many satellites for my 3-story, ~3K square feet home but I didn't have a problem running 3 satellites with my RBR50 system. I have tried positioning the satellites in various other places, as far as possible from the base, but without any success.
Every time a new firmware version appears I try turning on a second satellite to see if the issue might be fixed, but even with the latest V3.2.17.12 I still see the issue. I'm not interested in playing with power levels or doing more experimentation. I'm able to continue with 2 of my satellites powered off, hoping for a future firmware fix.
donawalt
Mar 16, 2021Hero - Experienced User
Back to my original post - it failed again tonight - upload speed was about 3 Mbps. So I went to the next suggestion FURRYe38 I disabled LAG at the modem, removed the second cable modem -> RBR cable, power ccled the modem, and power cycled the router. I guess we will see how that works!
- FURRYe38Mar 16, 2021Guru - Experienced User
OK, keep us posted...
