donawalt
Mar 15, 2021Hero - Experienced User
RBR850 needs a reboot every 2-4 days - how to stop?
I wanted to share with you a problem I have been seeing with my RBR850 installation plus 4 satellites. Periodically, maybe every 2-4 days, the performance in streaming from multiple Apple TV apps (li...
- Mar 20, 2021
Possible or your wifi environment is getting too saturated with wifi signals having that many RBS online. Remember, these things cover up to a good decent range so the wifi over lap will be out there a ways. So this should allow for more coverage and range using less RBS units. I get great coverage with just two or some times even 1 RBS in a 5000 sq ft home including basement.
Keep the 4th RBS as a backup in case something happens.
Enjoy.:smileywink:
MarkEncinitas
Mar 16, 2021Aspirant
Mikey - you seem to be describing a very similar issue to what I'm having.
It's driving me nuts.
I'm running RBR850 with 2 satellites; randomly during the day I just lose connection to devices but it seems only those connected to the satellites, not the main router.
Not sure if this is also what is causing problems in this post as I've seen restarting the router seems to help.
Anyways, thanks.
donawalt
Mar 17, 2021Hero - Experienced User
FURRYe38 it failed again last night, couldn't even stream at all, speeds very low. Previously in the last step I had disabled LAG at the modem, removed the second cable modem -> RBR cable, power cycled the modem, and power cycled the router.
Yesterday I also moved the satellite further back into the kitchen, still in eye contact and only 20 feet from the TV, but maybe 40 feet from the other staellite on that floor (which is on the other side of a plaster wall). Should I try removing this satellite closes to the TV? I would then have 1 RBR and 3 RBS, an RBS each on floors 1,2 and 3. The RBS is in the basement were the cable comes in.
Or do you have another idea? Thanks for your help!
- FURRYe38Mar 17, 2021Guru - Experienced User
Darn.
Lets try with just the RBR and 1 RBS and see.Starting to wonder if there is hardware problem....:smileyembarrassed:
- donawaltMar 17, 2021Hero - Experienced User
I am on the same path re: satellites. I actually did remove the 4th satellite, and walked around with a Wifi/RSSI analyzer, and the dignals are fine in that room without it. I was thinking, the thing that makes my config a little different than most is having 4 satellites. So going back to 3 might be a good first try. I would prefer trying this before tkaing 2 more satellites offline, as the network is needed in the house and I suspect there would be some bad dead spots. If you recall, the problem may not manifest itself for 2-3 days.
I do have an identical RBR850 from another house that I could swap in if I needed to try that eventually.
I'll report back! Thanks for your help FURRYe38
Awesome, sounds like a good plan.
Let us know how it goes in a few days.
