donawalt
Mar 15, 2021Hero - Experienced User
RBR850 needs a reboot every 2-4 days - how to stop?
I wanted to share with you a problem I have been seeing with my RBR850 installation plus 4 satellites. Periodically, maybe every 2-4 days, the performance in streaming from multiple Apple TV apps (li...
- Mar 20, 2021
Possible or your wifi environment is getting too saturated with wifi signals having that many RBS online. Remember, these things cover up to a good decent range so the wifi over lap will be out there a ways. So this should allow for more coverage and range using less RBS units. I get great coverage with just two or some times even 1 RBS in a 5000 sq ft home including basement.
Keep the 4th RBS as a backup in case something happens.
Enjoy.:smileywink:
donawalt
Mar 20, 2021Hero - Experienced User
FURRYe38 here is my update!
It's been 4 days and things are still working like a champ. I tried to use the Apple TV a lot, and it's been perfect. With Speedtest on the Apple TV it's been a pretty consistent 270 Mbps down, 40 Mbps up.
So it does seem like with a 4th satellite, the RBR either got confused, or due to location things would get messed up. It's been running fine with 3 satellites, I guess I didn't need the 4th one. This seems like some sort of bug to me.
This morning I turned Ethernet Port Aggregation back on - we'll see if it breaks or not!
Mar 20, 2021Guru - Experienced User
Enjoy.:smileywink:
