thsiao
Jan 09, 2021Aspirant
RBR850 needs weekly restart
I purchased an RBR850 that came with a satellite RBS850 about a year ago and didn’t really have any issues with it. A few months ago I added another satellite RBS850 and that’s when I started to see i...
Jan 10, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Armor, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
thsiao
Jan 16, 2021Aspirant
My firmware is V3.2.16.22 and I have not done any factory resets to the system other than making sure all devices are on the same firmare. My IPV6 was already disabled and my channels where 1 and 44. I changed them to 6 and 48 to see if that helps. The 20/40 coexistence does not allow me to select one only. Only on or off so I turned it off to see if that helps.
- thsiaoJan 16, 2021AspirantI also set both to short preamble. We’ll see if it helps. Sick of turning off/on my modem and router every 3-4 days.
- FURRYe38Jan 16, 2021Guru - Experienced User
Checking the 20.40Mhz box sets 40Mhz only.
Let us know.
