michaelm8718
Feb 03, 2021Guide
RBR850 Nest camera disconnections
Hi Any ideas as to why my nest cameras keep disconnecting constantly? I have 2 outdoor ones and two indoor plus a Hello. I tried the settings suggested elsewhere in the forum but no luck. I also ...
brainstewn
Aug 02, 2021Tutor
I discoverd that when the wirless security options is set to "NONE" the nest doorbell is found and works well on the Orbi RBR850. When I enable security using any of the three options the next doorbell is offline. I have started a ticket with Google Nest Support and they have it flagged as "Consult" and I was told that a senior technician is pursuing a solution. They offered to do a three way call with Netgear Support which may be my next troubleshooting step.
- michaelm8718Aug 02, 2021Guidebrainstewn
Thanks for the response
At the end I sold my Orbi router set as I started having other issues, difficulty upgrading etc. So I figured for a set that costs best part of a £1000 it was not worth it and I managed to sell it for most of my money and bought a single Asus RXA86U and all is wonderful!! No disconnections and everything works wonderfully.
So I reckon it was the router. My Arlo Pro 3 work really well and so does my Nest Hello!
