DudeDah
Dec 08, 2022Aspirant
RBR850 no longer recognizing Apple HomePod Mini
Hi folks, hope someone here can help... After a reboot of my router and satellite (RBR/RBS850 - not sure if it was after a firmware update or just one of my random reboots) one of my four Apple H...
Dec 08, 2022Guru - Experienced User
FYI about Apple devices:
Has the OS on the Apple devices been updated recently?
How is the wifi settings configured on the RBR?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
DudeDah
V4.6.9.11_2.3.5
yes, it is running the most recent firmware.
I'm running it in AP Mode...is that what you're asking?
2300 sq. ft.
~47 feet
2.4 is set on Auto and 5 is set on 48.
- FURRYe38Dec 08, 2022Guru - Experienced User
What the pod working before the OS update?
How many RBS are deployed? One or two?
What is the brand and model of the host router that the Orbi system is connected too?
- DudeDahDec 08, 2022Aspirant
The HomePod was having the same issue rejoining the network before the OS update. I was hoping the new OS would fix the issue but id did not. There is only one RBS in my setup. The host router is a C3000Z.
What security mode do you have set on the RBR for WiFi? Does WPA2 and TPIK change anything?
The pod won't connect to the RBR if you turn OFF the RBS?
You can try a FW update to see if this might help:
