rovers
Jun 06, 2020Aspirant
RBR850 not able to block websites
Under the security tab for the router it shows "block sites" but it doesn't allow me to sellect it. I am running the newest firmware 3.2.15.25. I am still also unable to load armor onto the router ...
Jun 07, 2020Guru - Experienced User
Has a factory reset and setup from scratch been performed since last update? Walk thru the setup wizard. After completing it, the Armor popup window should appear for you.
rovers wrote:Under the security tab for the router it shows "block sites" but it doesn't allow me to sellect it. I am running the newest firmware 3.2.15.25. I am still also unable to load armor onto the router as well through the app. I have tried manually reloading the new firmware with no better results.
