russellmoran99
Feb 11, 2022Luminary
RBR850 not connecting RBS750 Satellite after switching to AP Mode
I purchased my RBR850 with 2 satellites and they work great. I purchased RBS750 for my son's room and worked great until yesterday. My RBR850 router function drops the connection from the internet ...
- Feb 13, 2022
SOLVED:
After updating all, I started reading a little more. I saw folks using a pfSense router which I was as well. One common denominator was making sure even though this was in AP mode, I still had to hook the WAN line from pfSense to the RBR850. Once I did this, I rebooted the RBR850 and was able to connect the RBS750 both wired and wirelessly.
Feb 11, 2022Guru - Experienced User
russellmoran99
As far as I know the latest. I ran a firmware update prior to moving to AP mode and everything said it was up to date. I currently can’t login to see if as it’s not connecting.
- FURRYe38Feb 11, 2022Guru - Experienced User
Need to check to make sure the RBS750 is on same version of FW.
Can you connect the RBS750 to the back of the RBRs LAN port using a LAN cable to see if it connects?
Turn OFF the other RBS's while working with the 750 RBS.
- russellmoran99Feb 12, 2022LuminaryHow do it do this when I can’t get it to connect? I do not know how to login to it since it doesn’t connect. Any advice is appreciated.
- FURRYe38Feb 12, 2022Guru - Experienced User
If you ethernet connect the RBS to the back of the RBR, see if the the RBS gets a IP address from the RBR. If it does, try to log into the RBS web page using it's IP address in a web browser, log in maybe admin and >password< if it doesn't fully sync to the RBR.
