russellmoran99
Feb 11, 2022Luminary
RBR850 not connecting RBS750 Satellite after switching to AP Mode
I purchased my RBR850 with 2 satellites and they work great. I purchased RBS750 for my son's room and worked great until yesterday. My RBR850 router function drops the connection from the internet ...
- Feb 13, 2022
SOLVED:
After updating all, I started reading a little more. I saw folks using a pfSense router which I was as well. One common denominator was making sure even though this was in AP mode, I still had to hook the WAN line from pfSense to the RBR850. Once I did this, I rebooted the RBR850 and was able to connect the RBS750 both wired and wirelessly.
russellmoran99
As far as I know the latest. I ran a firmware update prior to moving to AP mode and everything said it was up to date. I currently can’t login to see if as it’s not connecting.
Feb 11, 2022Guru - Experienced User
Need to check to make sure the RBS750 is on same version of FW.
Can you connect the RBS750 to the back of the RBRs LAN port using a LAN cable to see if it connects?
Turn OFF the other RBS's while working with the 750 RBS.
- russellmoran99Feb 12, 2022LuminaryHow do it do this when I can’t get it to connect? I do not know how to login to it since it doesn’t connect. Any advice is appreciated.
- FURRYe38Feb 12, 2022Guru - Experienced User
If you ethernet connect the RBS to the back of the RBR, see if the the RBS gets a IP address from the RBR. If it does, try to log into the RBS web page using it's IP address in a web browser, log in maybe admin and >password< if it doesn't fully sync to the RBR.
- russellmoran99Feb 13, 2022Luminary
It did not sync, I had to use the admin-->password to log in
The RBS750 is on
Hardware Version: RBS750Firmware Version : V4.6.3.16RBR850Model Name Device Name Current Firmware Version StatusRouter RBR850 RBR850 V4.6.3.16 No Internet Satellite Orbi Satellite Russ No Internet Satellite RBS850 Orbi Satellite Bedroom V4.6.3.16 No Internet Satellite RBS850 Orbi Satellite Kuhn V4.6.3.16 No Internet
