russellmoran99
Feb 11, 2022Luminary
RBR850 not connecting RBS750 Satellite after switching to AP Mode
I purchased my RBR850 with 2 satellites and they work great. I purchased RBS750 for my son's room and worked great until yesterday. My RBR850 router function drops the connection from the internet ...
- Feb 13, 2022
SOLVED:
After updating all, I started reading a little more. I saw folks using a pfSense router which I was as well. One common denominator was making sure even though this was in AP mode, I still had to hook the WAN line from pfSense to the RBR850. Once I did this, I rebooted the RBR850 and was able to connect the RBS750 both wired and wirelessly.
russellmoran99
Feb 13, 2022Luminary
All has been updated. I have tried to add the RBS750 both wired and wireless and it fails. I have also did the 30-30-30 reset on the RBS750 prior to adding it. Failed. Please advise and thank you.
russellmoran99
SOLVED:
- FURRYe38Feb 14, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
