Coffeecup's avatar
May 30, 2021
RBR850 not connecting to Logitech Squeezebox
I just upgraded from the RBR50 to the RBR852 and now my Squezzebox cant connect to my WiFi.  Any ideas or suggestions?  Thanks
  • FURRYe38's avatar
    Remove the check mark from the 2.4 and or 5Ghz check boxes. Apply the change.
