bingbongbello
Apr 25, 2022Tutor
RBR850 not getting 2.5gbps
I upgraded to 2.5gbps and am maxing out at gigabit, tested on rbr850 through orbi app, wired directly to modem. all cabling is cat6. can confirm modem is getting 2.5gbps or thereabouts. any ideas?
- Apr 25, 2022
fixed! bell technician had ethernet plugged into LAN port in back of modem - there's a 10gpbs port. tried that and orbi is up to 2.5.
thanks for trying to help!!!
Apr 25, 2022Guru - Experienced User
bingbongbello
Apr 25, 2022Tutor
FW: 4.6.3.16_2.0.51
Connected to a Home Hub 4000 aka Sagemcom 5689.
- FURRYe38Apr 25, 2022Guru - Experienced User
What's the connection rate show on the Connection Status for the WAN port on the RBRs web page under Advanced Tab?
- bingbongbelloApr 25, 2022Tutor
There ya go.
Also recommend a CAT6A STP cable between the RBR and ONT at some point.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
