srosenthal33
Feb 28, 2024Follower
RBR850 Not getting 2gb speed Xfinty
I upgraded to Xfinity 2gb speed. When I run a speed test within the Orbi app it shows I am getting 1gb to the Orbi. Is there a setting I need to change or why am I only getting 1gb to the Orbi?
Feb 28, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed?
Turn off and unplug modem.
Turn on computers and rest of network.
