Dexter68
May 04, 2022Tutor
RBR850 not reachable after Firmware 4.6.8.2 upgrade attempt
Hi there, I have an RBR850 set in AP mode and connected to 3 satellites. The Orbi Router (AP) and my entire network receives their addresses from my main VPN router. My setup was working quit...
- May 14, 2022
Just to report that a Factory reset did the trick.
- Held the reset button for 15 sec as indicated by others
- Connected a laptop directly to a LAN port
- Went into Orbilogin.com thought the browser
- Followed the setup wizard, set the wireless credentials as per my original setup
- Since this is not my primary router, went and set it up in AP mode
- Verified DHCP assignments were being done by my primary router
- Checked that my wireless devices were connected and opened the Orbi app in my phone
- Re-synched my satellites and checked in the web browser their status, one by one, close to the RBR unit
- Placed the satellites in their final positions
- Checked everything went up and connected through the house
- Made a backup of the setup
- Disconnected the wired laptop and went back in wireless
- All good but it took time!
Thanks to FURRYe38 and others for your help
May 04, 2022Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Dexter68
May 04, 2022Tutor
Thanks Fury,
I didn’t do these steps while upgrading the router. I will complete them and report back.
R/Dexter
R/Dexter
- Dexter68May 06, 2022Tutor
Hi, I tried the first approach as suggested with no result. I will proceed with a Factory reset as soon as I get some time.
thanks again for the recommendations.
- Dexter68May 14, 2022Tutor
