Dexter68
May 04, 2022Tutor
RBR850 not reachable after Firmware 4.6.8.2 upgrade attempt
Hi there, I have an RBR850 set in AP mode and connected to 3 satellites. The Orbi Router (AP) and my entire network receives their addresses from my main VPN router. My setup was working quit...
- May 14, 2022
Just to report that a Factory reset did the trick.
- Held the reset button for 15 sec as indicated by others
- Connected a laptop directly to a LAN port
- Went into Orbilogin.com thought the browser
- Followed the setup wizard, set the wireless credentials as per my original setup
- Since this is not my primary router, went and set it up in AP mode
- Verified DHCP assignments were being done by my primary router
- Checked that my wireless devices were connected and opened the Orbi app in my phone
- Re-synched my satellites and checked in the web browser their status, one by one, close to the RBR unit
- Placed the satellites in their final positions
- Checked everything went up and connected through the house
- Made a backup of the setup
- Disconnected the wired laptop and went back in wireless
- All good but it took time!
Thanks to FURRYe38 and others for your help
May 15, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
