s1ujhe
May 06, 2022Aspirant
RBR850 not reachable after Firmware 4.6.8.2 upgrade attempt
I have not been able to resolve, and i've done a factory reset on router and both satellites. Network is working just fine. Only the mobile ORBI app and the web mgmt site cannot access Orbi network...
- May 06, 2022
What browser are you using? Try MS Edge, Firefox or Opera
orbilogin.com or 192.168.1.1 should bring up the initial setup wizard after pressing the reset button for 15 seconds then release and the front LED slowly blinks WHITE.
s1ujhe wrote:
Thanks - tho direct ethernet to router, still not able to get into 192.168.1.1 or others after factory reset. I don't see a setup wizard in your reply...
May 06, 2022Guru - Experienced User
Factory reset and setup from scratch using a wired PC or laptop and web browser and navigate to 192.168.1.1 or orbilogin.com in the web browser. Walk thru the setup wizard here.
- s1ujheMay 06, 2022Aspirant
- FURRYe38May 06, 2022Guru - Experienced User
All good. Didn't hold reset button long enough for reset. Held for a good 15 seconds - 10 seconds after flashing. Once that completed on router n sats, wizard came right up. Network still intact. Simply lost some device names.
