s1ujhe's avatar
s1ujhe
RBR850 not reachable after Firmware 4.6.8.2 upgrade attempt
I have not been able to resolve, and i've done a factory reset on router and both satellites.  Network is working just fine.  Only the mobile ORBI app and the web mgmt site cannot access Orbi network...
  • FURRYe38's avatar
    What browser are you using? Try MS Edge, Firefox or Opera
    orbilogin.com or 192.168.1.1 should bring up the initial setup wizard after pressing the reset button for 15 seconds then release and the front LED slowly blinks WHITE.
    s1ujhe wrote:
    Thanks - tho direct ethernet to router, still not able to get into 192.168.1.1 or others after factory reset.  I don't see a setup wizard in your reply...
