s1ujhe
May 06, 2022Aspirant
RBR850 not reachable after Firmware 4.6.8.2 upgrade attempt
I have not been able to resolve, and i've done a factory reset on router and both satellites. Network is working just fine. Only the mobile ORBI app and the web mgmt site cannot access Orbi network...
- May 06, 2022
What browser are you using? Try MS Edge, Firefox or Opera
orbilogin.com or 192.168.1.1 should bring up the initial setup wizard after pressing the reset button for 15 seconds then release and the front LED slowly blinks WHITE.
s1ujhe wrote:
Thanks - tho direct ethernet to router, still not able to get into 192.168.1.1 or others after factory reset. I don't see a setup wizard in your reply...
s1ujhe
May 06, 2022Guru - Experienced User
- s1ujheMay 06, 2022Aspirant
All good. Didn't hold reset button long enough for reset. Held for a good 15 seconds - 10 seconds after flashing. Once that completed on router n sats, wizard came right up. Network still intact. Simply lost some device names.
- FURRYe38May 06, 2022Guru - Experienced User
AH, it's always the little things. Glad you got working.
Enjoy. 📡- todd92May 07, 2022Initiate
Please make a sticky to hold the reset button for 15 seconds. Fixes the admin connectivity problem with the FW update. Just go back in and rename everything the way you had it before. Everything will reconnect fine.
