karenesbs
Nov 28, 2023Aspirant
RBR850 not sending IP address after power outage
This has been an ongoing issue with me for eight months now. I lose power and most of my devices cannot obtain an IP address. I then must do a hard reset (sometimes several hard resets in a row for i...
Nov 28, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰️
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
