karenesbs
Nov 28, 2023Aspirant
RBR850 not sending IP address after power outage
This has been an ongoing issue with me for eight months now. I lose power and most of my devices cannot obtain an IP address. I then must do a hard reset (sometimes several hard resets in a row for i...
Nov 28, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰️
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
karenesbs
What Firmware version is currently loaded? Firmware Version V7.2.6.21_5.0.20
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? ISP is Trailwave fiber optic, modem is GigaSpire Blast Model u6x GS4227
How many RBS are deployed? This was in my original post - there are four satellites, if that's what RBS means.
What is the size of your home? Sq Ft? 1600 sq ft, but there are satellites in other buildings on the property. All satellites are are more than 30 feet away from each other.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RB and RBS
Does this happen with the RBS turned OFF? yes
Does this happen with both wireless and wired devices? yes
2.4 GHz Channel Auto (9)
5 GHz Channel 36 + 40(P) + 44 + 48
- FURRYe38Nov 28, 2023Guru - Experienced User
First off, the model ISP ONT indicates it has a router and wifi built in. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...Are these 100 devices deployed all with in the home or spread out to the remote buildings?
What is the distances of these remote buildings from the main home and from the RBR? If too far away and building materials included, could be causing problems. Orbi was not designed to work wirelessly with RBS located in remote buildings and work with in the main home building.
Try this, turn OFF all RBS accept for the RBR. Pull the power adapter for the RBR for 1 minute then back On. Just testing the devices in the home building, do devices get an IP address in the home building after the RBR comes back to ready?
For 1600 sq ft, a RBR and just one RBS would be needed in the main home building.
Try channels 1, 6 or 11 on 2.4Ghz.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.250.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
https://kb.netgear.com/25722/How-do-I-reserve-an-IP-address-on-my-NETGEAR-router
I would power OFF the ISP modem for 1 minute. Factory reset the router and power it off. Power ON the ISP modem and let it sync. Then power ON the router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
Or use the ERASE button on the routers web page to factory reset the router:
https://kb.netgear.com/000062081/How-do-I-erase-the-configuration-settings-on-my-Orbi-WiFi-System- karenesbsNov 28, 2023Aspirant
I forgot to mention that the ISP modem is already bridged - that did not help.
MOST devises are within the home. The ones not in my home or Dad's home are wireless cameras scattered on the property and an automatic door opener for the chickens. The two buildings are approximately 50' away, downhill. One is in my Dad's home - the reason why I purchased this system in the first place, and the other one is in a shed to cover areas for my wireless cameras. My apologies, I meant 1900 sq ft, not 1600. The house is a ranch. Router is in center of home, one satellite is at one far corner of house, the other satellite is at the opposite corner of the house.
As for testing - if I am unable to change the router name and password to the old information - which I cannot, then nothing will connect because they are not set up to connect. I already spend hours reconnecting all my devises to the second router, I am now on my third router.
Yes, a factory reset was done after latest FW update. I have done MANY factory resets over the last eight months.
50' maybe to far in between for RBS and the RBR in the main home build to service the remote building that far away over wireless and having to deal with over 100 devices. If there was a ethernet cable connected between the two buildings, this would work better:
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System 📡 ‌‌🛰️
Well for this size home, the RBR and just one RBS should work but having over 100 devices, maybe taxing the system some. So if you have two RBS connected, lets try this, try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
You can change the wifi SSID name and PW back to same after any factory reset. I recommend using the routers web page to setup the RBR and RBS when doing any factory reset:
Using same custom SSID name and PW is recommended.
Be sure to save off a backup configuration to file after next FR so you can save time if you need to FR again:
Also, the DHCP IP address pool has been changed to several different options over the last few weeks in hopes that something would work.
