sbernardnc
Sep 13, 2021Tutor
RBR850 not syncing w satellites after being turned off
I have an RBR850 system with 2 satellites. Firmware Version: V3.2.18.1_1.4.14, Router is connected by ethernet to main computer. Previously both satellites were detected and synced. I have not...
Sep 13, 2021Guru - Experienced User
Sync the RBS using the sync button in back on the RBS then RBR.
Did this started recently?
What version of the orbi app are you using? Does this happend on different mobile devices?
Uninstall the app, reboot device then reinstall app.
Do the RBS appear on the RBRs web page?
sbernardnc
Sep 13, 2021Tutor
| Hardware Version | RBR850 |
| Firmware Version | V3.2.18.1_1.4.14 |
| GUI Language Version | V3.0.0.51_2.1.30.3 |
| Operation Mode | Router |
| LAN Port | |
| MAC Address | 08:36:C9:8F:C2:91 |
| IP Address | 192.168.1.1 |
| DHCP | On |
Arris, Model # TG1672G, using when first installed. No upgrades recently
Did this started recently? Yes, only after turning off system 3 times, last in late August.
What version of the orbi app are you using? Version 2.11.6.0
Does this happend on different mobile devices? Only have one phone w Orbi app--had worked seamlessly before.
Uninstall the app, reboot device then reinstall app. Done already by re-installing app and then rebooting but can try in this sequence
Do the RBS appear on the RBRs web page? Yes, appears to pair (blue light) but not will not sync
- FURRYe38Sep 13, 2021Guru - Experienced User
What mode is the modem working in? Bridge or router mode? This model modem has a built in router FYI.
Possible that this maybe a Orbi app issue...
- sbernardncSep 13, 2021Tutor
Modem has settings that came when gotten--router. Have never used as a router, always w NG router/access point--current ORBI is upgrade from Nighthawk that worked well for some time. Currently one of the satellites is recognizing two devices--an ipad and my iphone, but this info doesnt show up on ORBI app as before. Will try to remove and reboot and then re-install app.
For future reference about your modem:
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopIf the Orbi app process doesnt' seem to fix this, I'd go over to the Orbi app forum and post about this there:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Maybe something going on with the app...
