Orbi_in_Orbit
Feb 02, 2022Tutor
RBR850 on 4.6.7.5 firmware wifi download isssue
i have a RBR850 on 4.6.7.5 firmware with a single satellite. RBR850 has a static IP address and is bridged by the ISP. I recently upgraded bandwidth to a 1 Gbps down and 500 Mbps up package. If i ...
Orbi_in_Orbit
Feb 05, 2022Tutor
The ISP modem is an Arris nVG448BQ. I'm testing on multiple devices Windows 10 and 11. Windows 11 is definitely slower.
The Windows 10 device (Dell with KillerAX 1650 or realtek ethernet) and i can get decent throughput on wired connections on both RBR and RBS. Wireless...most i can squeeze out on either is 530 Mbps down and 490 Mbps up. That's after the reset, multiple power downs. There is no interfering wireless....at least in reasonable signal strength. Even cutting out the RBS, I still suffer the same issue. Wired performance is acceptable. Wireless is not. I was expecting the move to 1 Gbps download would be 800-900 Mbps down on wireless. I've also tested with broadcom wireless (N) ...and i get about the same speed as i do on an AX enabled wireless.
Mikey94025
Feb 05, 2022Hero
Orbi_in_Orbit wrote:Wireless...most i can squeeze out on either is 530 Mbps down and 490 Mbps up. That's after the reset, multiple power downs. There is no interfering wireless....at least in reasonable signal strength. Even cutting out the RBS, I still suffer the same issue. Wired performance is acceptable. Wireless is not. I was expecting the move to 1 Gbps download would be 800-900 Mbps down on wireless. I've also tested with broadcom wireless (N) ...and i get about the same speed as i do on an AX enabled wireless.
Wireless has limits, even with wi-fi 6. I don't think you should expect speeds much more than 600 Mbps, and that's the max under even ideal conditions (which are usually not the case).
- FURRYe38Feb 05, 2022Guru - Experienced User
Actually for WiFi6 you can get near 900mpbs and over that as well. Depends on client device support and antenna MIMO confguration.
I've see 700Mpbs on my iphone and constantly see over 900Mbps with a RAXE500 in wireless bridge mode set up as a client.
