Cwdudley
Apr 16, 2024Aspirant
RBR850 only one device connects
My Orbi will only connect to a single device. Factory reset and the issue persists. Of course the app says everything is fine and I have 80 devices happily connected. Not an issue with my ISP as I ke...
CrimpOn
Apr 16, 2024Guru - Experienced User
Please explain what indicates that only a single device connects to the Orbi system?
(Technically, devices connect to WiFi systems. WiFi systems do not connect to devices.)
- Does only one device in the house function? (The other 79 are not working?)
- Does the Orbi web interface Attached Devices display only one device?
It would be useful to understand the network topology. "What is connected to what?" and using which ports?
There have been numerous posts on the forum where users have placed the Orbi router in Access Point (AP) mode and cabled the router and satellites in a way that prevents the router from detecting devices attached to satellites.
Cwdudley
Apr 17, 2024Aspirant
The former, only one will function. I haven’t touched any settings from factory default and unsure how to change the access mode (I assume through the web interface?). Is it possible it changed on its own or needs to be manually flipped off by me? Thanks both for hopping in to help 🙂
- CrimpOnApr 17, 2024Guru - Experienced User
The WiFi name printed on the label appears as an available system, and the smartphone running the Orbi app can connect to that WiFi using the password printed on the label, can access the internet and the Orbi app, correct?
But no other device can access the WiFi network?
Do you recognize the other devices listed in the Orbi app as being in the house?
(i.e. the Orbi app is describing this router and not some other system?)
