njsteblay
Apr 12, 2020Tutor
RBR850 ORBI Wifi 6 - Cannot connect to some devices - solved
I just bought the RBR850 Orbi Wifi 6 with one satellite. I've been having problems connecting my Amazon Firecube and an Insignia Google Home Clock. After disabling the AX capability in Basic/Wirele...
- Apr 13, 2020
Good to hear. Please mark your thread and solved.
Enjoy.
Apr 12, 2020Guru - Experienced User
Yes for some reason NG changed these values to a low one. 2346/7 should work. Normally 2346 is default for most NG wifi routers.
njsteblay
Apr 13, 2020Tutor
Yes you are correct. It is the CTS/RTS Threshold setting that impacts the older devices. I re-enabled the AX features and all older devices are still connecting. So I would recommend that everyone set their CTS/RTS Threshold to the max to avoid issues.
- FURRYe38Apr 13, 2020Guru - Experienced User
Enjoy.
- UltradogApr 27, 2020Tutor
I have an RBK852, there are separate CTS/RTS Threshold settings for 2.4 & 5.0. Should I set one or both to 2347?
(Link to the original post brings me to this post)
- FURRYe38Apr 27, 2020Guru - Experienced User
Both...
