heyandy
Mar 21, 2021Initiate
RBR850 Orbi WiFi 6 losing WPA2 security with two satellites
So today was the third time in a year that I wake up to find that my phone is not connected to my home Wifi... Goto Wifi settings on phone to see my SID being broadcast, but without any security (h...
Apr 06, 2021Guru - Experienced User
Any progress on this?
heyandy wrote:So today was the third time in a year that I wake up to find that my phone is not connected to my home Wifi... Goto Wifi settings on phone to see my SID being broadcast, but without any security (have it configured for WPA2-PSK (AES)).. Force the connection onto the unsecured network (and no, no one in the neighborhood is spoofing my Wifi). Login to the router via brower, and see WPA2-PSK (AES) is sedt, and password is correct. Reboot the network, same results.
Unplug the second floor satellite, unplug my first floor satellite, unplug main router and wait 15 seconds. Plug in main router, phone now needs my original WPA2 password to connect. Run upstairs, plug in first floor satellite, run up stairs, plug in second floor satellite. All devices connect that were previously configured with same WPA2 password.
Look at Network Map or via browser, both satellites are showing offline, but each satellite is showing no light, flashing or otherwise. However, I know both satellites are woriking fine, because both are hard wired to a hub in each room, and my iPad's and Laptop that are using WiFi are showing hardwired to the main router in the basement.
This is becoming annoying! I am sure tomorrow I will reset the whole network and add the two satelittles again, starting wirelessly, and then plug them in, I am sure it will work again for another few months.
I am always checking for latest firmware (3.2.16.22 as I write this). What gives?
vajim
Apr 07, 2021Master
how did you make out?
