NorthLondon892
Sep 21, 2021Aspirant
RBR850 Out Of Sync after upgrade to Firmware 4.6.3.16
Hey everyone. Could someone help me please? I did an update to my Orbi RBR850 router to the latest firmware V4.6.3.16_2.0.51 Since doing this, the satellite in the bedroom is coming up with an "Ou...
Sep 21, 2021Guru - Experienced User
What Firmware version is currently loaded on the RBS? Be sure the RBS FW is updated to same version as RBR.
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
- NorthLondon892Sep 21, 2021Aspirant
Current firmware version is V4.6.3.16 and is loaded on the router and all the satellites
The modem is a Virgin hub 4 , provider is Virgin
I have rebooted several times
- FURRYe38Sep 21, 2021Guru - Experienced User
What mode is your ISP modem working in? Router or Bridge mode?
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop- NorthLondon892Sep 21, 2021AspirantHi there .
I am not sure what this has to do with my satellite being out of sync after a firmware version upgrade?
My Virgin hub is in modem only mode .
