astonmartinv8
Aug 09, 2022Aspirant
RBR850 plus 2 x RBS850 satellites- 1 satellite cycles flashing white and solid blue light constantly
Hi There, I wonder if the community can help. I recently purchased an RBK852 pack (1 x RBR850 and 1 x RBS850) PLUS an add-on RBS850 satellite (which was not part of the original pack). Firmwa...
Aug 09, 2022Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What happens if you swap RBS with each other?
astonmartinv8
ISP modem is a TP-Link Archer VR1600v.
Property is a single level 3-bed apartment, about 1750 sqft, sort of rectangular. Router is in the middle and about 30-35ft from each satellite. 2 x glass windows and fair bit of concrete wall between each in each direction.
I haven't swapped the RBS but will try that. Good point.
One thing I am wondering is whether I actually need a second satellite.
- FURRYe38Aug 10, 2022Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.For that size of home ya, having the RBR along with two RBS maybe too much wifi: https://youtu.be/UR0viMLISz4
I would turn off one RBS ane reduce the transmit power on the RBR from 100% to 50%. Under Advanced Tab/Advanced Settings/Wireless Settings
- astonmartinv8Aug 10, 2022Aspirant
Thank you. I went for option 3. Wifi was already turned off, but the Orbi was not in AP mode. Now it is. All of the Orbi's are still stable and performance is still the same.
The add-on satellite still cycles flashing white and solid blue light with no performance impact.
So the router is now in AP mode, but the original problem remains.
Does anyone know why the add-on satellite would constantly cycle through flashing white and solid blue light without any performance problem. What is the root cause of that? Does it signify a particular error?Given my performance is good throughout the whole apartment, I am not sure about the too much wifi as yet, unless it is the cause of the add-on satellite's weird light cycle!
- FURRYe38Aug 11, 2022Guru - Experienced User
What happens if you swap RBS location with the other RBS?
Might remove the RBS from the RBRs web page, factory reset the RBS and then press the sync button on the RBS then the RBR. Do this with the RBS in the same room as the RBR. Turn OFF the other RBS temporarily while you work with this one RBS thats not working right.
