CrazyEddie
Jan 17, 2021Apprentice
RBR850 poor backhaul status
I've got an Orbi RBR850 router and two RBS850 satellites. The router is on our main floor. The satellite upstairs (directly above the router) shows "good" for backhaul status, and was just added today...
Jan 17, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. Depending upon distance and building materies, it maybe common to see a poor status for 1 RBS.
Swap RBS placements with the other to see if status changes or follows.
CrazyEddie
Many thanks to your reply and follow-up questions. My answers:
- The firmware reflected on the web UI is V3.2.16.22_1.4.9
- The cable provider is Xfinity and the cabel modem/router is their XB7-T, which I believe is made by Broadcom
- I would say the size is ~6k square feet (although I've got the router and satellite so close that I'm not sure the size is impacting the setup)
- I estimate the distance from the router to the "good" backhaul status is less than 30 feet, and the distance from the router to the basement might be about the same distance, or slightly further away
- I will swap the satellites in the morning to see if there is a difference. FWIW, both satellites were "good" today when I had them within ~6 feet of the router when I added the 2nd satellite
- There are a handful of wifi neighbors - beside, behind and across the street - I can see seven from my Mac wifi drop down menu
- CrazyEddieJan 18, 2021Apprentice
Updates:
- This morning both satellites are showing "good" under backhaul, but internet seemed to be completely down last night and this morning for the upstairs satellite. After unplugging the device and turning WiFi on and off on my phone, I was able to connect to the mesh network.
- Here are the speeds I got:
- Using the Orbi app, my speeds were pretty consistently ~1190Mbps download and ~42Mbps upload, with the exception of the basement, which was ~940M/42M. (It has always seemed to me that the Orbi app speed is faster than the Ookla Speedtest app.) All other speeds below are with the Ookla app.
- Upstairs satellite (eventually) - 555/40 and 723/41
- Main floor: wired to Xfinity modem (942/42); WiFi at the router location (928/41); elsewhere on same floor (211/39)
- Downstairs: wired to the satellite (244/18 and 326/40); WiFi at the satellite (396/41 and 289/32).
- FURRYe38Jan 18, 2021Guru - Experienced User
What mode is the ISP modem working in? Router or Bridged? This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop- CrazyEddieJan 18, 2021Apprentice
Thanks! Responses to questions below:
I'm pretty sure the ISP modem is in router mode, as I merely set it up with phone instructions from the ISP. I had my own modem (I believe it was one of the latest Netgear modems) that I tried to use with them, but it didn't seem to work and after some frustration, I gave up on it. I did, however, purchase another modem that is not in use - an Arris SB8200 - if that would help in this procss.
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.Let me do some investigation on this option. The last time I mucked around with the modem, I exceeded my technical capability and managed to pi$$ off everyone in the house. "It wasn't so bad before, and now it doesn't even work!" I suppose worst case is just another call to Xfinity to go back to what it is now. If I try this option, should I try to use the new Arris at the same time, or just limit my variables?
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.I will hold on this pending my success/failure on #2
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopNote - the Orbi router is already connected to the Xfinity modem via an ethernet cable.
Thanks for the help, and patience. I know that I'm quite ignorant on this topic.
