mmorain
May 25, 2022Tutor
RBR850 port forwarding not working after recent fix
I've recently received the fix for being unable to access my Orbi management interface, and that seems to have resolved that issue (thanks ChristineT !). However, since that issue started, I have...
- May 25, 2022
One more reboot seems to have resolved this issue. Thank you!
mmorain
May 25, 2022Tutor
- FURRYe38May 25, 2022Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
