alternet
Mar 07, 2023Tutor
RBR850, RBS850, 2x RBS350 "Out of sync" & default "password"!!!
Hi all, I got RBR850 with RBS850 ....for a while everything worked well. After a while I had to add some more coverage to my system and got 2 additional satellites RBS350 (following compatibility...
alternet
Mar 15, 2023Tutor
Tried from RBR:
...and from the RBS end it is not possible since only manual upgrade is possible:
Mar 15, 2023Guru - Experienced User
Try sending the RBS FW file to the RBS web page?
- FURRYe38Mar 15, 2023Guru - Experienced User
Wondering if there is a FW issue being with FW on the 8 series is at v4.6.x and the RBS350 series is at v4.4x and .4.x not working with the v.6.x FW?
- alternetMar 15, 2023Tutor
FURRYe38 wrote:Wondering if there is a FW issue being with FW on the 8 series is at v4.6.x and the RBS350 series is at v4.4x and .4.x not working with the v.6.x FW?
No an idea where the problem is. Just please be also informed that the RBR does not recognize the RBS350 series properly (see the details):
Ya maybe a Auto Update service issue or since the RBS350 isn't correctly synced, this would be a result for this area.
NG will need to look in to this.
Open a support ticket if you haven't already.
