MikesTooLz
Mar 14, 2022Aspirant
RBR850 rebooting every 2 hours
So after my internet went out for 3 days due to damage to an outside cable my router was now rebooting on its own every 2-3 hours. This went on for a full week, every 2-3 hours it would reboot and in...
MikesTooLz
Mar 17, 2022Aspirant
Orbi Router Firmware: V4.6.7.13
Modem: TG3482G
Time Server setting in Orbi Router was updated from default netgear time server to Googles Time Server and its gone a week without rebooting.
Mar 17, 2022Guru - Experienced User
What mode is your modem in?
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
