JulianHa
Feb 06, 2022Guide
RBR850 rebooting multiple times/day
I am 16 months into the journey with the RBR850 and my manageable stability (1 spontaneous reboot of the RBR850/day) has moved to multiple, sometimes multiple per hour. I am running the current offic...
- Feb 09, 2022
Yep - more than a day of uptime! sounds like victory, but ... :) Anyway, good to go and now i just have toe figure out a VPN solution.
Feb 06, 2022Guru - Experienced User
What actual firmware version you on? There's a few on the forums that are newer than the release version you could try.
- JulianHaFeb 06, 2022Guide
Thanks Plemans,
I am currently on the last 'official' for my product (or at least where my auto updates take me) - namely V4.6.3.16_2.0.51
I have seen the discussion around v4.6.7.5 which i will try to get loaded today as GearHead support again seems to be very 'consumer'. Ran into an issue in teh small hours with the manual RBS upload dialog boxes (browser pop-ups) generating 'blank' when i selected the RBSs for manual upgrades. Will advise on the stability once i get all 3 decvices onto v4.6.7.5
best, JulianHa- JulianHaFeb 07, 2022Guide
I updated the FW on the RBR850 andf 2 RBS850 to V4.6.7.5_2.1.7
So a brief update after 22 hours. I've had two resets (one i witnessed) and one i saw from the overnight record. I think that is more stable, but not 'stable'.
- FURRYe38Feb 07, 2022Guru - Experienced User
What reset? The RBR or RBS?
Did you power OFF the ISP modem, RBR and RBS for 5 mniutes then back on after the FW update or did you do a full on factory reset?
