JulianHa
Feb 06, 2022Guide
RBR850 rebooting multiple times/day
I am 16 months into the journey with the RBR850 and my manageable stability (1 spontaneous reboot of the RBR850/day) has moved to multiple, sometimes multiple per hour. I am running the current offic...
- Feb 09, 2022
Yep - more than a day of uptime! sounds like victory, but ... :) Anyway, good to go and now i just have toe figure out a VPN solution.
Feb 07, 2022Guru - Experienced User
Could be anything at this point. My hopes is that the double NAT issue maybe the primary cause. Either using the DMZ on the Linksys for the RBR in router mode or configuring the RBR for AP mode will fix the reboot thing. Have two routers on the same line can cause various problems. And we don't know the status and condition of the Linksys router as well. It's FW up to date? Thats a moderatly older router and going on in age. I personally bailed Linksys about 10 years ago due to them not updating FW and leaving bugs behind on the WRT1900 series. I still have my WRT1900AC I use once in a while as a wireless client. Taking this out of the mix and testing should see results.
JulianHa
Feb 07, 2022Guide
Thanks again FURRYe38
The Linksys is up to date but ultimately flashed with ExpressVPN code as that is the function. i have switched off just about everythign on teh linksys. BTW - i'm using the 3200 as it has the most horsepower to process the encrypt/decrypt and leave me with at least reasonable up/down bandwidth. Will see if i can verify or resolve the possible NAT conflcts and see if that gets me stable
- FURRYe38Feb 07, 2022Guru - Experienced User
- FURRYe38Feb 08, 2022Guru - Experienced User
Any updates on this?
Did you remove the Linksys router or leave it on line and put the RBR in to the Linksys DMZ or Configure AP mode on the RBR with the Linksys in router mode?
- JulianHaFeb 08, 2022Guide
Hi FURRYe38,
I had to remove it in the end. I had one of those fun conversations with ExpressVPN's support folks where we explored all conceiveable mitigations to nought. There flashed s/w has limited capability, so no DMZ, no other approaches we could get to, so i have taken the flashed Linksys WRT3200ACM out of the path leaving the ISP gateway CM1000 connected into RBR850.
Since taking it out, the only unforced reset on the RBR was at 11.15pm, so 12 hours ago. That's a big improvement, but not pristine. 70 devices connected.At the same time i'm researching VPN options H/W, withing RBR850s openVPN and others to get things back behind a wall. Open to suggestions, but again would need to be a service provider model at teh other end of the pipe (e.g. express or Nord, etc.)
Call me paranoid, but i believe in makign my security better than those who aren't.best, julian
Thats a shame theres no DMZ.
Sounds like the reboots are fixed. I hope.
Ya, you'll find something in regards to VPN.
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡 - JulianHaFeb 09, 2022Guide
- FURRYe38Feb 09, 2022Guru - Experienced User
Yay. Glad it's working. Im sure you'll find something.
Enjoy. :smileywink:And Good Luck.
