JulianHa
Feb 06, 2022Guide
RBR850 rebooting multiple times/day
I am 16 months into the journey with the RBR850 and my manageable stability (1 spontaneous reboot of the RBR850/day) has moved to multiple, sometimes multiple per hour. I am running the current offic...
- Feb 09, 2022
Yep - more than a day of uptime! sounds like victory, but ... :) Anyway, good to go and now i just have toe figure out a VPN solution.
Feb 08, 2022Guru - Experienced User
Thats a shame theres no DMZ.
Sounds like the reboots are fixed. I hope.
Ya, you'll find something in regards to VPN.
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
