magoldsm1
Aug 25, 2020Aspirant
RBR850: Remote Management and Port Forwarding
I just installed an RBR853 system, replacing my RBR50, so I have some familiarity with ORBI. Ihave set up port 80 forwarding to a specific machine on my network (VAULT). My public IP address is XXX...
Mikey94025
Aug 26, 2020Hero
I suspect you're trying this access using your public IP on your home network. What happens when you try it outside your network? Your security concerns for #1 and #3 matter if the access works the same outside your network.
I have Double NAT on my home network right now so my public IP goes to my ISP modem's admin page if within my home network, but does not work the same if I connect to a different network (e.g., hotspot from my mobile phone) so there is no actual security concern or risk of outsiders accessing internal admin sites.
Mikey94025
Aug 26, 2020Hero
Incidentally, this NAT Loopback behavior was only recently supported by RBR850: https://kb.netgear.com/000049578/Which-NETGEAR-routers-support-NAT-loopback
