skyward1
Mar 26, 2020Apprentice
RBR850 Requires Daily Reboot to Get Normal Connection Speeds
Hello NG Community, I have the RBK852 system (RBR850 router and RBS850 satellite), running v3.2.10.11_1.2.12, and have recently experienced extremely slow connection speeds. My Internet connection ...
- Apr 27, 2020
Hey Furry and all,
Sorry, not WAN. It was a conflict between the router and modem. My modem was (still is) at 192.168.0.1 and my router was at 192.168.1.1. That is where the problem was. I went to 172.16.0.1 for my router, changed all my static IPs to fall under that, and lett DHCP assign the others normally. All is happy!
I will be closing this post as solved, but I actually solved it, so how can I do that?
Thanks annd stay safe!
sky
Mar 26, 2020Guru - Experienced User
Are speeds tested both wired and wireless?
Have you power OFF the ISP modem/ONT for 1 minute then back on?
Has a factory reset and setup from scratch been performed since last update?
skyward1
Hello again Furry!
My modem is an Arris SB8200 with a COmcast gigabit connection. I have not rebooted the modem, only the router; which 'fixes' it for a day.
The speed tests were for a wired connection. LAN was normal. WAN is the problem.
I have not performed a reset and setup from scratch, as all was working just fine thorough the FW fiasco. I went from the 10.1 beta to the 10.11 with no issues.
I really don't want to do a reset and reinstall, as I have a lot more going on to take care of, but if that will be the fix, then I'll suck it up.
Please advise!
Thank you and stay safe!
sky
- FURRYe38Mar 26, 2020Guru - Experienced User
Power OFF the ISP modem and RBR for 1 minute, then back on with the ISP modem and RBR lastly.
A reset maybe needed if you haven't done one yet since last update. v10.11 FW files are now availalbe for download so a freash load would be a good idea as well.- skyward1Mar 27, 2020Apprentice
Hello Furry,
I did the reboot sequence of the modem, router, and satellite. I'll see how that goes in the next day or two.
If there are still issues (and I am sure there will be) and I need to reset the modem and satellite and install new (more hours wasted) and reconfigure fresh, what do you recommend so I can be done with this once and for all? I need to use my system for work and household device use. If I take the system down, I will not be able to do any work and my wife and others in my house will not be able to use their devices. So, I want to get this right if I have to take the system down again, and be done with it.
I am already running the latest FW, but you mentioned it is available for download. What do you mean by that? Am I to downgrade the FW to a previous version for the satellite and router and then upgrade to the latest FW? If I reset, it will dump all of my settings and keep the current FW, so I don't understand why you mentioned the new FW being available.
Anyhow, I have a lot of devices on static IPs, so it will be a mess to redo everything as I believe you will not want me to use my backup file,from what I have seen you telling others about a 'fresh' reset.
If I do need to go with the maximum reset, would you tell me the steps I need to do please?
Thanks for your help and stay safe!
sky
- skyward1Mar 29, 2020Apprentice
No change in router connection speed issue. It is a daily occurance. I reboot the router and it works fine until the next day.
Please give me the full instructions to clear this up once and for all. I want to move on with my life and hopefully have the most expensive router in the world be the least of my worries and troubles.
sky
