airbone42
May 14, 2021Tutor
RBR850 restart several times a day
Since around 2 weeks I have the issue that my RBR850 is rebooting (white pulsing) automatically several times a day which is pretty annoying. Sometimes even several times in an hour. I already insta...
airbone42
May 15, 2021Tutor
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. It's a wired connection
So is the RBS directly wired to the RBR?
Yes
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update? There is no ISP modem. Has a power off for 1 minute then back ON with Orbi system been performed since last update? Might try a factory reset on the RBR as well if the power OFF doesn't change it.
Yes that has been made. Is there a recommended way to restore the configuration after a factory reset? Due to the amount of connected devices and their connection to each other a reset without resotring the configuration is not a viable solution in production.
airbone42
May 15, 2021Tutor
> 30 feet is too far....keep an eye on the sat ring...the color will guide
As mentioned already in the beginning the color is pulsing white. The satellite has a wired connection.
