pingpongdad
May 09, 2022Aspirant
RBR850 returning "Refused to Connect"
Hi, I have a RBR850 router with 3 satellites that I have been using for about a year. It has ip 192.168.1.1, and I have been able to access it using that ip from my web browser (mac/chrome). Toda...
May 09, 2022Guru - Experienced User
NG is aware of this. Seems to be working on a fix currently.
Was your FW updated that you know of recently?
Are you try HTTP instead of HTTPS with 192.168.1.1?
What happens if you power OFF the RBR. Disconnect it from the ISP modem, then back ON and try HTTP and 192.168.1.1?
pingpongdad
Thank you for the response. I'm not aware of any recent firmware updates, although I might have set it on auto update. I tried https as well but it didn't work either.
