Johngl1
Sep 28, 2020Follower
RBR850 router led light is solid white
My RBR850 router is working fine but the led light is on solid white (the large led light at the bottom of the router). How can I get it to turn off? I've done all I can think of - reboot, power cy...
motesewed
Jan 24, 2021Aspirant
It is fiber optic cable so not sure about the modem as it is not in the house. I have the latest firmware installed and the router had been working flawlessly for two months and just recently started with the lights.
Jan 26, 2021Guru - Experienced User
Any progress on this?
motesewed wrote:It is fiber optic cable so not sure about the modem as it is not in the house. I have the latest firmware installed and the router had been working flawlessly for two months and just recently started with the lights.
- motesewedJan 26, 2021Aspirant
I have a laptop connected directly through the Fiber Optics so I can compare speeds with the RBR 850. Speeds are comparable from router and the laptop. I have anywhere from 41 to 50 devices connected (depending on kids visiting) and all have good connections with good streaming and content response. There are 5 streaming video cameras attached (doorbell and 4 cameras) which work without a flaw. The only problem I have is the constant light on the router. The satellite has good backhaul connectivity and no led lights.
My setup: Windstream Fiber Optics (1 gig up and 1 gig down)>RBK 852 (V3.2.16.22_1.4.9). This system replaced RBK 40.
- FURRYe38Jan 26, 2021Guru - Experienced User
Try a full power OFF of the ISP modem and RBR for 1 minute, then back ON.
Does logging into the RBRs web page do anything to the front LED?
motesewed wrote:I have a laptop connected directly through the Fiber Optics so I can compare speeds with the RBR 850. Speeds are comparable from router and the laptop. I have anywhere from 41 to 50 devices connected (depending on kids visiting) and all have good connections with good streaming and content response. There are 5 streaming video cameras attached (doorbell and 4 cameras) which work without a flaw. The only problem I have is the constant light on the router. The satellite has good backhaul connectivity and no led lights.
OK...turning off the modem and the RBR did not turn off the light. Logging into the RBR does nothing to the light. The light came on about a month ago after two months of not being on. For the first three weeks it was a pulsing light and then for about a week it has been a solid light. Worked with Netgear support for about 6 hours and nothing changed except it went from a pulsing light to a constant light.
