Kunson
Feb 09, 2022Aspirant
RBR850 satellite 5ghz automatically disabled
Hello there. I purchased orbi rb854 suite and setup as router mode with PPPOE ISP. Three satellites use ethernet connect (use cisco switch). I used the network almost month occur few problems can...
- Feb 16, 2022
If your using v5 FW and have done a full factory reset on the RBR and RBS and the RBS continues to disable the wifi radio when it's ethernet connected, it would be a HW problem. Mine have been ethernet connected since I applied v5 FW and no radios are disabled.
NG support needs to look into this one RBS.
Feb 10, 2022Guru - Experienced User
Kunson wrote:
Hello there.
What is the model# of the ethernet switch in the configuration?
Is this switch connected to the RBR? https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System 📡
What Cat# LAN cable is being used? CAT6 is recommended.
I used the network almost month occur few problems can't be resolve even upgrade to latest firmware (v4.6.7.5)
problem 1: use computer (side of one satellite) ping to orbi main router delpy is not stable. Mostly deplay is 2-9ms but every minute occur 100-300ms and turn back to 2-9ms.
problem 2: all clients in area lost connection. showing dhcp no IP (phones and mac computer). in this time login into this area satellite show 2.5ghz and 5ghz network disabled.
model version: orbi RB854
firmware: v4.6.7.5.
wifi-users: iphone13promax; cameras; macs.
screenshot: https://drive.google.com/file/d/1PjR-hEajMeFXkM8eg2RMLrMHFwLhNmeq/view?usp=sharing
https://drive.google.com/file/d/1mAFc1gXGnPK7BPMzEzYMDfWpRTI08mKX/view?usp=sharing
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected. Even if RBS are ethernet connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
- KunsonFeb 11, 2022Aspirant
Yes. I did factory reset many times and tried resync. cannot resolve this problem.
- FURRYe38Feb 11, 2022Guru - Experienced User
Is this switch connected to the RBR? https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-Sy... 📡
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡- KunsonFeb 12, 2022Aspirant
Thanks for your reply
My home use CAT6 Lan cable.
And my home have three rooms and each room use one satellite with wired ethernet connect to main orbi.
My home total almost 1200 Sq. one room 277Sq.
So the problem is too much RBS on my house?
Thanks.
