Kunson
Feb 09, 2022Aspirant
RBR850 satellite 5ghz automatically disabled
Hello there. I purchased orbi rb854 suite and setup as router mode with PPPOE ISP. Three satellites use ethernet connect (use cisco switch). I used the network almost month occur few problems can...
- Feb 16, 2022
If your using v5 FW and have done a full factory reset on the RBR and RBS and the RBS continues to disable the wifi radio when it's ethernet connected, it would be a HW problem. Mine have been ethernet connected since I applied v5 FW and no radios are disabled.
NG support needs to look into this one RBS.
Kunson
Feb 11, 2022Aspirant
Yes. I did factory reset many times and tried resync. cannot resolve this problem.
Feb 11, 2022Guru - Experienced User
What is the model# of the ethernet switch in the configuration?
Is this switch connected to the RBR? https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-Sy... 📡
What Cat# LAN cable is being used? CAT6 is recommended.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected. Even if RBS are ethernet connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
- KunsonFeb 12, 2022Aspirant
Thanks for your reply
My home use CAT6 Lan cable.
And my home have three rooms and each room use one satellite with wired ethernet connect to main orbi.
My home total almost 1200 Sq. one room 277Sq.
So the problem is too much RBS on my house?
Thanks.
My satellites between almost 20~25 ft to each one..
- FURRYe38Feb 12, 2022Guru - Experienced User
For 1200 sq ft, the RBR alone would be enough. Maybe 1 RBS set out at 30 feet.
I'd turn OFF all RBS and test with just the RBR alone. If you need to add a RBS, find a good remote location out at 30 feet. If the distance can't be at 30 feet, you can turn down the power output on the RBR from 100% to say 50% and this would help with a bit too much signal strength between the RBR and RBS being too close.
- KunsonFeb 13, 2022Aspirant
Thanks for your advice.
I just tried just one RBR and one satellites far out 30 ft. it problem still existed.
And I want keep my rooms have enough RSSI for low latency.
Do we have any other solutions?
