Kunson
Feb 09, 2022Aspirant
RBR850 satellite 5ghz automatically disabled
Hello there. I purchased orbi rb854 suite and setup as router mode with PPPOE ISP. Three satellites use ethernet connect (use cisco switch). I used the network almost month occur few problems can...
- Feb 16, 2022
If your using v5 FW and have done a full factory reset on the RBR and RBS and the RBS continues to disable the wifi radio when it's ethernet connected, it would be a HW problem. Mine have been ethernet connected since I applied v5 FW and no radios are disabled.
NG support needs to look into this one RBS.
Kunson
Feb 16, 2022Aspirant
Thanks for you helps!
This problem should be firmware problem? or hardware problem? and how to confirm what is the cause of this issue.?
Feb 16, 2022Guru - Experienced User
