oigoldman
Feb 06, 2022Tutor
RBR850 Satellite Disconnecting Due to Possible DHCP Issues
I have an RBR850 with one hardwired satellite. After running flawlessly for the first year, sometime in the last few months I started having trouble with WiFi devices disconnecting for a few minutes ...
- Feb 22, 2022
The satellite connects directly to the router, without a switch. However, the old cable was CAT 5e. Turns out, it was also from the same roll used for a different run that also caused trouble a while back.
I replaced it with a new CAT 6 run, switched back to the wired backhaul, and everything is running smoothly. It hadn't occurred to me that the cable might be at fault, especially as it had worked for quite some time. Thanks for the helping in tracking this down.
oigoldman
Feb 12, 2022Tutor
So I tried disconnecting the ethernet and using wireless backhaul instead. After five days the problem hasn't recurred, suggesting it is indeed a problem with the cable. I haven't tracked that down yet, but in the meantime, it's working reliably again. Thanks!
- FURRYe38Feb 13, 2022Guru - Experienced User
Is the RBS directly connected to the RBR or is there a LAN switch in between?
What CAT# cable are you using? CAT6 is recommended.
- oigoldmanFeb 22, 2022Tutor
- FURRYe38Feb 22, 2022Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
