mdunbar1985
Oct 11, 2021Aspirant
RBR850 satellite not broadcasting WIFI
Hi, guys. I have two Orbi RBR850 AX6000 tri-band networks I am having trouble with. One was purchased October 2020, and the other November 2020. One is at home and one is at my office. Both have firm...
Oct 11, 2021Guru - Experienced User
Can you access the RBS web page at all using it's IP address?
Try turning one RBS OFF and leave the other ON.
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
mdunbar1985
Thanks, Furry. I will try these out and report back.
FURRYe38 wrote:What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?
- FURRYe38Oct 11, 2021Guru - Experienced User
Please give feedback to the question presented as well. Thank you.
