scanlont
Dec 17, 2020Aspirant
RBR850 Schedule blocks services, but does not unblock.
My Orbi RBR850 will turn on blocking services for my son's xbox at the time scheduled to block services every night at 10:00. But it will keep blocking them in perpetuity and not unblock them at the...
HomeUserguy
Jan 09, 2021Aspirant
I have a similar problem with the 850.. you would thinkg for the top model basic feature would work. I have found the schedule doesnt seem to respect the days of the week. The time on it seems to work for me.
I would validate you NTP settings to make sure they are accurate.
Logon to Orib
Advanced --> Admin --> NTP
check the date and time to make sure it matches.
scanlont
Thanks for the ideas. I've restored to factory 4 times now. Which is always a three hour hassle for the family in lockdown. I've probably checked the date/time 20+ times.
- FURRYe38Jan 09, 2021Guru - Experienced User
Do you have IP address reservations set up on the RBR for our devices your trying to control?
How many devices are you controlling?
scanlont wrote:Thanks for the ideas. I've restored to factory 4 times now. Which is always a three hour hassle for the family in lockdown. I've probably checked the date/time 20+ times.
- scanlontJan 09, 2021Aspirant
I do, just for that 1 device, an XBOX.
- FURRYe38Jan 10, 2021Guru - Experienced User
I would reach out to NG support to see if there maybe any additional information on this. Let them know what your seeing. Something I don't happen to use on my system here. I would agree the control should work as expected.
